When I try to click on my external hard drive I get a pop-up error that reads
Error mounting /dev/sdb1 at /media/andrew/Untitled: Command-line `mount -t "exfat" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,iocharset=utf8,namecase=0,errors=remount-ro,umask=0077" "/dev/sdb1" "/media/andrew/Untitled"' exited with non-zero exit status 32: mount: unknown filesystem type 'exfat'
What is the issue here, and how can I go about fixing it? Thanks in advance for any help.
Ron
  • 20,938
cosmoflop12
  • 1,189
  • 15
  • 24
First, you need to enable the universe repository. If you have not done it already, run:
sudo add-apt-repository universe, then update the system with:
sudo apt-get update
Install the below packages to auto mount your exFAT formatted device:
sudo apt-get install exfat-fuse exfat-utils
or continue with the manual mount as you were trying.
Ron
  • 20,938
