I'm trying to install the mutate launcher on Ubuntu 14.04, but I'm having problems with all the methods suggested in the readme.
If I use the ppa method I receive:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you ependencies problem]are using the unstable distribution that some
required packages have not yet been created or been moved out of Incoming.
unity-control-center :
Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E:Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I tried installing those separately, but didn't work
sudo apt-get install libcheese-gtk23 libcheese7
libcheese-gtk23 is already the newest version.
libcheese7 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
What could I do?
