Hello I recently installed Ubuntu 14.04.2 and at first I had problems with overheating. I had to install the drivers for the Nvidia Geforce GT630M card and seems to have been solved.
Anyway, I have the feeling that you still have overheating problems, I installed lm-sensors for temperature and after sudo sensors-detect I get this:
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0:  +53.0°C  (high = +87.0°C, crit = +105.0°C)
Core 0:         +53.0°C  (high = +87.0°C, crit = +105.0°C)
Core 1:         +53.0°C  (high = +87.0°C, crit = +105.0°C)
Core 2:         +53.0°C  (high = +87.0°C, crit = +105.0°C)
Core 3:         +53.0°C  (high = +87.0°C, crit = +105.0°C)
Apparently it seems that the temperature is right. However, the heat coming out of the laptop is very hot and if I open more windows chrome, play video in youtube the temperature rises above 60 °C. It may also be because it is very hot in summer but I'm surprised I had never seen my laptop so hot.
Therefore install lm sensors for fan speed if the fan is spinning slower than normal but the problem that I have is that it does not detect me. When I do a sensors-detect this are modules that detects me:
# Chip drivers
coretemp
I've looked at this forum and many websites possible answers but none has helped me.
Thank you for your attention
Edit with result sudo lshw -C display,cpu
*-cpu
   descripción: CPU
   producto: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
   fabricante: Intel Corp.
   id físico: 27
   información del bus: cpu@0
   versión: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
   ranura: SOCKET 0
   tamaño: 2860MHz
   capacidad: 3800MHz
   anchura: 64 bits
   reloj: 100MHz
   capacidades: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm ida arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms cpufreq
   configuración: cores=4 enabledcores=4 threads=8
  *-display
   descripción: VGA compatible controller
   producto: GF108M [GeForce GT 630M]
   fabricante: NVIDIA Corporation
   id físico: 0
   información del bus: pci@0000:01:00.0
   versión: a1
   anchura: 64 bits
   reloj: 33MHz
   capacidades: pm msi pciexpress vga_controller bus_master cap_list rom
   configuración: driver=nouveau latency=0
   recursos: irq:49 memoria:c0000000-c0ffffff memoria:e0000000-efffffff memoria:f0000000-f1ffffff ioport:4000(size=128) memoria:c1000000-c107ffff
  *-display
   producto: 3rd Gen Core processor Graphics Controller
   fabricante: Intel Corporation
   id físico: 2
   información del bus: pci@0000:00:02.0
   versión: 09
   anchura: 64 bits
   reloj: 33MHz
   capacidades: msi pm vga_controller bus_master cap_list rom
   configuración: driver=i915 latency=0
   recursos: irq:47 memoria:c1400000-c17fffff memoria:d0000000-dfffffff ioport:5000(size=64)
A.B.
  • 92,125
Garmael
  • 153
Adjust the fan speed with nbfc
My laptop is an Acer Aspire E5-573G nothing else worked to control its CPU fan, but nbfc. I'm using Ubuntu 18.04. The exact profile for my model is missing, but nbfc worked fine with another similar profile (Acer Aspire E5-575G). If you don't know which profile to use, you can try: mono nbfc.exe config -r
Also I edit the default profile to turn the fan policy more agressive. So you can edit one for your machine, too.
marciowb
  • 121
My machine's CPU sensor is currently running at 61 °C with 10 % CPU usage.
It goes up to 72 °C at 50 % and 78 °C at 100 % CPU usage.
If both GPU and CPU are running at 100 % the internal sensor even goes up to to 91 °C
As long as your CPU Sensor doesn't get to the critical stage for your processor you're fine … :-)
Fabby
  • 35,017
Nvidia proprietary driver is not installed according to your output.
You have hybrid graphics and both adapter always work.
That is the cause of overheating.
Install the driver by running
sudo apt-get install nvidia-331 nvidia-prime
and reboot.
You will be able to switch adapters in Nvidia Settings program. If you switch to Intel, power consumption and heating must be minimal.
Pilot6
  • 92,041
