Hi all Below is a link to the pastebin that contains the tail of the error log produced by VMware Workstation 11. Questions related to this topic are for Specific versions previous versions of linux. Can anyone please help me troubleshoot this?
The issue is related to The last line where it is unable to start VMNET. I have tried disconnecting from my VPN and ;launching VMware with no success.
http://pastebin.com/p0zVCLVi
Thanks! PB
Copy the snippet from here and paste it into a file in your home directory named vmnet313.patch.
Run the following commands
cd /usr/lib/vmware/modules/source
tar -xvf vmnet.tar
patch vmnet-only/filter.c < ~/vmnet313.patch
tar -uvf vmnet.tar vmnet-only
rm -r vmnet-only
/usr/lib/vmware/bin/vmware-modconfig --console --install-all
What is done in the code block above is untar the source of vmnet, patch the problematic code and then return the vmnet module back to it's original state with the added patch.
Source
Unable to run VMware - Failed to build vmnet
nixpower
  • 1,230
  • 19
This Solution is for kernel 3.19 .
Here is a link to the solution of the above problem:-
3.19 kernels and up
Since 3.19 kernel the vmnet module will fail to build. Therefore we need to patch it .Commands are given below :-
curl http://pastie.org/pastes/9934018/download -o /tmp/vmnet-3.19.patch
Extract the vmnet module sources:
if curl command is not found then run : sudo apt-get install curl
tar -xf vmnet.tar
Apply the patch:
patch -p0 -i /tmp/vmnet-3.19.patch
Recreate the archive:
tar -cf vmnet.tar vmnet-only
Remove leftover:
rm -r *-only
Rebuild modules:
Now, VMware Workstation is running smoothly.
