[Running Ubuntu Desktop 14.04.2 x86_64 -- 3.16.0-41-generic -- on an Intel DuoCore T9300]
My Unity bar indicator-datetime disappeared suddenly about a week ago. No warning and no other problem apart from 2 days later the disappearance of indicator-stickynotes too.
Those two events only affect my account-session on my workstation. Other users on the same machine, using the same hardaware, are fine on both counts (indicator-stickynotes and indicator-datetime).
I am in the process of filing a specific bug for `indicator-stickynotes, although the coincidence is too much of a red-flag not to raise broader questions about the unity environment itself or perhaps before that, just about my user profile... In reality I am in the dark.
Interestingly indicator-datetime still shows in the Unity bar on the session login screen. After login it is gone. All system-settings are functional including the "Time & Date" one. Nothing is greyed or absent there as I read was the case elsewhere.
Since then I have read what appears to be duplicates on askubuntu.com as well as here. I did tried to apply proposed fixes, including fixes identifed as accepted solutions. I think I was thorough. Nothing worked.
Here is a quick replay of what I tried:
$ alias sag='sudo apt-get'
Then:
$ sag install indicator-datetime
Reading package lists... Done
Building dependency tree
indicator-datetime is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ apt-cache policy indicator-datetime
indicator-datetime:
Installed: 13.10.0+14.04.20140415.3-0ubuntu1
Candidate: 13.10.0+14.04.20140415.3-0ubuntu1
Version table:
*** 13.10.0+14.04.20140415.3-0ubuntu1 0
500 http://ftp.udc.es/ubuntu/ trusty/main amd64 Packages
100 /var/lib/dpkg/status
$ sudo dpkg-reconfigure --frontend noninteractive tzdata
Current default time zone: 'Europe/Berlin'
Local time is now: Fri Jun 26 18:35:43 CEST 2015.
Universal Time is now: Fri Jun 26 16:35:43 UTC 2015.
$ sudo killall unity-panel-service
exited quietly, with no visible change.
$ sudo restart lightdm
also produced no result.
$ ldd --verbose \
/usr/lib/x86_64-linux-gnu/indicator-datetime/indicator-datetime-service \
> output_ldd_indicator-datetime
$ cat output_ldd_indicator-datetime | grep -i -e "error" -e "warning" \
-e "missing"
52 libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0
(0x00007f0cb6504000)
450 /lib/x86_64-linux-gnu/libgpg-error.so.0:
$ sag remove unity-control-center 1> remove-log_unity-control-center
There is nothing of note in the remove-log file as far as I could see.
Then:
again exited quietly with no change at all in the unity bar.
Curiously as I tried to reinstall unity-control-center, I found it was already there, although I had just (apparently) removed it.
$ sag install unity-control-center
unity-control-center is already the newest version.
Help !! In need of suggestions assistance to solve this indicator-datetime + indicator-stickynotes disappearance.
EDIT 1:
$ /usr/lib/x86_64-linux-gnu/indicator-datetime/indicator-datetime-service
Indicator-Datetime-Message: indicator-datetime exiting; failed/lost bus ownership
