whenever i try to access my drive this appears and i can't access my drive. I am using 15.04 alongside windows 8.1
Error mounting /dev/sda2 at /media/sharif/EEE: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sda2" "/media/sharif/EEE"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda2': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
Jacob Vlijm
  • 85,475
Double S
  • 647
You need to disable Fast Boot in Windows 8.1.
How Fast Boot works? -
Windows 8 doesn't totally shut down when you click the Shut down command. Instead it only partially shuts down and partially hibernates. This is the Hybrid Shutdown part of the equation. Then, when you turn on your computer, Windows 8 starts very quickly because it only has to partially boot up and partially wake up. This is the Fast Boot part of the equation.
nsane
  • 486
