Hi Im kinda new to Ubuntu. That said, I can usually run this on a clean install of ubunty 14.10
sudo apt-get update
sudo apt-get install git
And then git should be installed
But what I get is this
me@server1:~$ sudo apt-get install git
[sudo] password for me:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 git : Depends: liberror-perl but it is not going to be installed
       Depends: git-man (> 1:2.4.5) but it is not going to be installed
       Depends: git-man (< 1:2.4.5-.) but it is not going to be installed
 mariadb-client-5.5 : Breaks: mariadb-server-5.5 (< 5.5.44-1ubuntu0.14.10.1) but 5.5.39-2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
me@server1:~$ git
The program 'git' is currently not installed. You can install it by typing:
me@server1:~$
it looks like apt-get does not install the dependencies automatically, and the git command just returs git is currently not installed. Running sudo apt-get -f install does not change anything
What am I doing wrong here? (Note: I dont want mariadb installed)
EDIT: After running sudo apt-get purge mariadb-client-5.5
 mariadb-client : Depends: mariadb-client-5.5 (>= 5.5.39-2) but it is not going to be installed
 mariadb-server-5.5 : Depends: mariadb-client-5.5 (>= 5.5.39-2) but it is not going to be installed
Oldenborg
  • 103
This error is coming because, your apt-get dependency tree has reached an inconstant state, due to the installation of mariadb-client package which is of newer/older version than as as expected by mariadb-server.
Try uninstalling mariadb-client by
$ sudo apt-get purge mariadb-client-5.5
Then try to correct your dependency tree by
 $ sudo apt-get -f install
And then try installing git.
