I changed the permission for /etc folder to 777 with chmod. When I try to run Sudo after that it refuses to work. I found a few fix, such as going to recovery mode to fix things but recovery mode is not an option for me as Grub is not loading at all. Even holding shift key or repeat Esc does not load Grub. I tried to update grub but again, that requires sudo! http://www.psychocats.net/ubuntu/fixsudo
r2d2@Sdnhbuz-r2d2:~$ sudo update-grub
sudo: /etc/sudoers is world writable
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
If you changed permissions recursively (with -R option) then you have a problem, because you have to restore the right permission for each file. If you only changed etc folder permission it is easy to solve.
Download and burn the ubuntu install cd (it is a live-cd).
Insert a live-cd (or a live-usb) in your computer and boot the machine using it (remember to tell your computer/bios to start from the cd/usb if it is not the first option).
Do not select "install ubuntu", select "try ubuntu".
With the live ubuntu running, mount your computer disk and change permissions.
If you don't known how to do it. You can open a terminal (or press Ctrl-Alt-t) and execute
sudo fdisk -l
This will list all your disks and partitions. Normally your computer disk will be /dev/sda and the main partition will be the greatest linux partition (I assume /dev/sda1). Then execute:
sudo mount /dev/sda1 /mnt
Don't worry, you are running the live ubuntu and sudo will work. Now go into mnt:
cd /mnt
and restore the permissions:
sudo chmod 755 etc
Now close the terminal, shutdown the live ubuntu and restart from your computer (eject the cd/usb before restart).
You can follow this process with any linux live-cd.
acesargl
  • 176
