I have a question about installing/upgrading Python packages using the tool pip.
I can either run
sudo pip install -U PACKAGENAME
or
pip install -U PACKAGENAME --user
What is the difference between those two commands and which one should I prefer...
  1. on my own machine?
  2. in the install script of a python program I publish?
Byte Commander
  • 110,243
To me the only difference is the scheme path.
Using sudo your package will be installed in:
/usr/local/lib/python2.7/dist-packages/
With --user they are installed in your $HOME directory in:
$HOME/.local/lib/python2.7/site-packages
For your own system, I'd say it does not really matter. Use --user if you're not a sudoer member.
For code you publish, avoid --user.
