I have an absolutely fresh install of Ubuntu 12.04 on a USB drive, made using the 64-bit PC (i386) Desktop image. By "fresh" I mean that all I have done is remove the casper-rw file and replace it with a large partition to increase persistence.
(Note: I already know I will not have these problems on 14.04 or 15.04; however, I need to use a tool that is only supported on 12.04, so upgrading is not an option.)
Apt-get update gives the following warnings, but since they are warnings rather than errors, I left them unchecked. They are not the subject of my question, unless they are part of the problem, but are provided in case they are important. The system's self-reported solution (run apt-get update) is obviously wrong because that is what generated the errors.
Fetched 3,253 kB in 16s (196 kB/s)
Reading package lists... Done
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ precise/main i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_precise_main_binary-i386_Packages)
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ precise/restricted i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_precise_restricted_binary-i386_Packages)
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ trusty/main i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_trusty_main_binary-i386_Packages)
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ trusty/restricted i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_trusty_restricted_binary-i386_Packages)
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ vivid/main i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_vivid_main_binary-i386_Packages)
W: Duplicate sources.list entry cdrom://Ubuntu 12.04.5 LTS _Precise Pangolin_ - Release amd64 (20140807.1)/ vivid/restricted i386 Packages (/var/lib/apt/lists/Ubuntu%2012.04.5%20LTS%20%5fPrecise%20Pangolin%5f%20-%20Release%20amd64%20(20140807.1)_dists_vivid_restricted_binary-i386_Packages)
W: You may want to run apt-get update to correct these problems
More troubling, and the actual problem, is that apt-get dist-upgrade exits with actual errors. The complete output of the second invocation (i.e., just the problematic parts) is:
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up linux-image-3.13.0-55-generic (3.13.0-55.94~precise1) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
initrd.img(/boot/initrd.img-3.13.0-55-generic ) points to /boot/initrd.img-3.13.0-55-generic  (/boot/initrd.img-3.13.0-55-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-3.13.0-55-generic.postinst line 491.
vmlinuz(/boot/vmlinuz-3.13.0-55-generic ) points to /boot/vmlinuz-3.13.0-55-generic  (/boot/vmlinuz-3.13.0-55-generic) -- doing nothing at /var/lib/dpkg/info/linux-image-3.13.0-55-generic.postinst line 491.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-55-generic /boot/vmlinuz-3.13.0-55-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-55-generic /boot/vmlinuz-3.13.0-55-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-55-generic
cryptsetup: WARNING: failed to detect canonical device of overlayfs
cryptsetup: WARNING: could not determine root device from /etc/fstab
run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-55-generic /boot/vmlinuz-3.13.0-55-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-55-generic /boot/vmlinuz-3.13.0-55-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 3.13.0-55-generic /boot/vmlinuz-3.13.0-55-generic
/usr/sbin/grub-probe: error: cannot find a device for / (is /dev mounted?).
run-parts: /etc/kernel/postinst.d/zz-update-grub exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-55-generic.postinst line 1025.
dpkg: error processing linux-image-3.13.0-55-generic (--configure):  subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-generic-lts-trusty:  linux-image-generic-lts-trusty depends on linux-image-3.13.0-55-generic; however:   Package linux-image-3.13.0-55-generic is not configured yet.
dpkg: error processing linux-image-generic-lts-trusty (--configure):  dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic-lts-trusty:  linux-generic-lts-trusty depends on linux-image-generic-lts-trusty; however:   Package linux-image-generic-lts-trusty is not configured yet.
dpkg: error processing linux-generic-lts-trusty (--configure):  dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-signed-image-3.13.0-55-generic:  linux-signed-image-3.13.0-55-generic depends on linux-image-3.13.0-55-generic (= 3.13.0-55.94~precise1); however:   Package linux-image-3.13.0-55-generic is not configured yet.
dpkg: error processing linux-signed-image-3.13.0-55-generic (--configure):
No apport report written because the error message indicates its a followup error from a previous failure.
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of linux-signed-image-generic-lts-trusty:  linux-signed-image-generic-lts-trusty depends on linux-signed-image-3.13.0-55-generic; however:   Package linux-signed-image-3.13.0-55-generic is not configured yet.
dpkg: error processing linux-signed-image-generic-lts-trusty (--configure):  dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-signed-generic-lts-trusty:  linux-signed-generic-lts-trusty depends on linux-signed-image-generic-lts-trusty; however:   Package linux-signed-image-generic-lts-trusty is not configured yet.
dpkg: error processing linux-signed-generic-lts-trusty (--configure):  dependency problems - leaving unconfigured
I am at a loss for what to do when upgrades go wrong to that extent on a fresh system; I'm not even sure what most of those things are.
(Edit: The tool I referenced above is the Nvidia Nsight Eclipse for the specific purpose of cross-compiling code with my laptop as host and an Nvidia Jetson development board as the target. My understanding is that only Ubuntu 12.04 is supported.)
Novak
  • 193
From official Nvidia website: The latest version of NVIDIA Nsight Eclipse Edition with support for CUDA C/C++ and is supported on MAC and Linux platforms. Just install the CUDA Toolkit and run 'nsight' on the command line.
Check it with:
apt-cache policy nvidia-cuda-toolkit
The packages included are listed here one of them as you can see nvidia-nsight: NVIDIA Nsight Eclipse Edition and it's maintained for all current supported Ubuntu distros.
To install nvidia-cuda-toolkit in terminal run:
sudo apt-get install nvidia-cuda-toolkit
CUDA 6.5 Toolkit for Ubuntu14.04 x86 64-bit (with TK1 cross-development support) can be downloaded from here http://developer.download.nvidia.com/compute/cuda/6_5/rel/installers/cuda-repo-ubuntu1404-6-5-prod_6.5-19_amd64.deb
More detailed info can be found here and here
JoKeR
  • 7,062
