119
Recently, I needed to get a list of packages that were installed on my Ubuntu system which were also put on hold for upgrade.
The 'hold' status for a package means that when the operating system is upgraded, the installer will not upgrade these packages either, unless explicitly stated in the options.
I am looking for a command-line solution but understand this may be possible from the GUI as well.
Anwar
  • 77,855
pmagunia
  • 1,702
  • 13
  • 14
5 Answers5
149
You can use apt-mark:
apt-mark showhold
this will show the packages that are kept in "hold" state so that the pacakge manager won't auto upgrade the packages.
From man apt-mark:
showhold
           showhold is used to print a list of packages on hold
heemayl
  • 93,925
28
Use dpkg
dpkg -l | grep "^hi"
The -l means to list all packages which are then piped into grep.
The regular expression "^hi" means to search for all lines that begin with "hi" which are initials for "hold" and "installed".
By default, dpkg -l will list the status, package name, version, architecture, and a short description.
pmagunia
  • 1,702
  • 13
  • 14
as an alternative you can also use dpkg --get-selections:
dpkg --get-selections | grep "\<hold$"
dpkg --get-selections lists the status of all installed packages and grep "\<hold$" only shows lines which end with the word "hold".
perhaps also interesting, if you are looking for irregularities - especially if the above shows nothing (useful), would be
dpkg --get-selections | grep --invert-match "\<install$"
this shows all lines/packages which are not just installed.
DJCrashdummy
  • 1,922
In apt-mark versions > 2.4 you have to use the following command:
apt-mark showhold
Also it is an old tool aptitude does a fine job on the command line and you can easily surf through the hold packages:
aptitude
Type u to update packages and then press g and you will see the held back packages.
abu_bua
  • 11,313
And to unhold all held packages, use
sudo apt-mark unhold $(apt-mark showhold)
xpt
  • 1,197
