How to install latest CouchDB on Ubuntu 12.04, 14.04, 15.04, 15.10, 16.04, etc?
I spent around an hour trying different ways and instructions for installing latest CouchDB on my Ubuntu 12.4 installation. I have posted the best way that I found as answer to save other peoples time.
5 Answers5
Install the latest stable release with the commands below:
sudo apt-get remove couchdb couchdb-bin couchdb-common -f
sudo apt-get install python-software-properties
sudo apt-add-repository ppa:couchdb/stable
sudo apt-get update
sudo apt-get install couchdb couchdb-bin couchdb-common -f
Source
A.B.
  • 92,125
Run this script:
cd /tmp
mkdir x
cd x
set -e
sudo apt-get update || true
sudo apt-get --no-install-recommends -y install build-essential pkg-config runit erlang libicu-dev libmozjs185-dev libcurl4-openssl-dev
wget http://mirrors.fe.up.pt/pub/apache/couchdb/source/2.0.0/apache-couchdb-2.0.0.tar.gz
tar -xvzf apache-couchdb-2.0.0.tar.gz
cd apache-couchdb-2.0.0/
./configure && make release
sudo adduser --system \
        --no-create-home \
        --shell /bin/bash \
        --group --gecos \
        "CouchDB Administrator" couchdb
sudo cp -R rel/couchdb /home/couchdb
sudo chown -R couchdb:couchdb /home/couchdb
sudo find /home/couchdb -type d -exec chmod 0770 {} \;
sudo sh -c 'chmod 0644 /home/couchdb/etc/*'
sudo mkdir /var/log/couchdb
sudo chown couchdb:couchdb /var/log/couchdb
sudo mkdir /etc/sv/couchdb
sudo mkdir /etc/sv/couchdb/log
cat > run << EOF
export HOME=/home/couchdb
exec 2>&1
exec chpst -u couchdb /home/couchdb/bin/couchdb
EOF
cat > log_run << EOF
exec svlogd -tt /var/log/couchdb
EOF
sudo mv ./run /etc/sv/couchdb/run
sudo mv ./log_run /etc/sv/couchdb/log/run
sudo chmod u+x /etc/sv/couchdb/run
sudo chmod u+x /etc/sv/couchdb/log/run
sudo ln -s /etc/sv/couchdb/ /etc/service/couchdb
sleep 5
cd /tmp/x/apache-couchdb-2.0.0
sudo sv status couchdb    mv rel/couchdb /usr/local/bin/
cd ..
rm -r /tmp/x
cat <<EOT >> /etc/systemd/system/couchdb.service
[Unit]
Description=Couchdb service
After=network.target
[Service]
Type=simple
User=couchdb
ExecStart=/usr/local/bin/couchdb/bin/couchdb -o /dev/stdout -e /dev/stderr
Restart=always
EOT
systemctl  daemon-reload
systemctl  start couchdb.service
systemctl  enable couchdb.service
service couchdb start
then open the url http://localhost:5984/_utils/
Kaf
  • 1,255
  1. Download the latest Source package of CouchDB from couchdb.apache.org and extract it
  2. Open INSTALL.Unix or any other appropriate readme or install file
  3. RTFM™ and follow instructions, install unmet dependencies if any and Relax!™
While this post is not focused on Ubuntu (but rather debian on a Raspberry Pi), I was successful in following these guidelines on Ubuntu:
http://jeeonthepi.blogspot.de/2014/08/installing-couchdb-1.html
Outline:
  1. Add Erlang repositories to your package manager
  2. Install Erlang
  3. Install spidermonkey
  4. Install libicu
  5. Install curl
  6. Set up user account for CouchDB
  7. Download CouchDB source code
  8. Do configure/make/make install
  9. Create soft links
  10. Make CouchDB config writable
brdlph
  • 109
Just try to use snap to install CouchDB.Only 2 commands needed.
sudo apt install snapd
sudo snap install couchdb
Source: Stack Overflow
muru
  • 207,228
Jayly
