I have "test1.csv" and it contains
200,400,600,800
100,300,500,700
50,25,125,310
and test2.csv and it contains
100,4,2,1,7
200,400,600,800
21,22,23,24,25
50,25,125,310
50,25,700,5
now
diff test2.csv test1.csv > result.csv
is different than
diff test1.csv test2.csv > result.csv
I don't know which is the correct order but I want something else, both of the commands above will output something like
2 > 100,4,2,1,7
3 2,3c3,5
4 < 100,300,500,700
5 < 50,25,125,310
6 \ No newline at end of file
7 ---
8 > 21,22,23,24,25
9 > 50,25,125,310
I want to output only the difference, thus results.csv should look like this
100,300,500,700
100,4,2,1,7
21,22,23,24,25
50,25,700,5
I tried diff -q and diff -s but they didn't do the trick. Order doesn't matter, what matters is that I want to see only the difference, no > nor < nor blank space.
grep -FvF did the trick on smaller files not on big ones
first file contains more than 5 million lines, second file contains 1300.
so results.csv should result in ~4,998,700 lines
I also tried grep -F -x -v -f which didn't work.
