Following my previous question in the subject and since no solution has been found:
I was wondering if there are any users of Ubuntu 15.04 which are experiencing this issue?
I have encountered this problem in both 12.04 and 14.04 following an update. Further updates appeared to fix the problem. I recommend you run update a few times. In the meantime I discovered a stop-gap measure which appears to work. When this happens, select "log in as other user" (select other user) and then log in as the same user. Your desktop reappears with all the same programs loaded and no data lost.
gyropyge
  • 2,568
