libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.4)
unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Asked
Active
Viewed 991 times
dikokob
- 1
- 1
Try resolving the dependencies manually, i.e.
apt-get install libcheese7
apt-get install libcheese-gtk23
apt-get install libglapi-mesa
If that doesn't work, try using aptitude, as its dependency resolution is often more effective than apt-get
apt-get install aptitude && aptitude -f install <thing-it-failed-on>
3_humped_CAML
- 46
- 4
I'm also having this problem. I think it is down to a steam bug. Even when i reinstalled Ubuntu 14.04. Hopefully they fix this soon. Does this solution work in the mean time?
