The error massage was:'
Error:BrokenCount>0'.
it said that
"this usually means that your installed packages have unmet dependencies."
What to do??!?!
it said that
What to do??!?!
    Try pressing ctrl+alt+f1, logging in as your user, and running sudo apt-get update && sudo apt-get upgrade && sudo apt-get install -f. You can get back to the GUI by pressing ctrl+alt+f7
    Make sure the repo sources are up to date and not broken:
sudo rm -rf /var/lib/apt/lists/*     #remove repo cache
sudo apt-get update                  #renew repo cache
Try to Install the package again.
sudo apt-get install packagename
Once the package determines that you have some missing dependencies, run the following command to fix broken or missing dependencies.
Above command will only download the missing dependencies if you have already installed the package.
