This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
lmms: Depends: lmms-common (= 2:1.1.3-1kxstudio5.2) but 2:1.1.3-1kxstudio5.2 is to be installed
      Depends: libqt4-xml (>= 4:4.5.3) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
      Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
      Depends: libqtgui4 (>= 4:4.5.3) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
      Depends: stk-rawwaves but it is not going to be installed
i need help
Thomas Ward
  • 78,878
Remove any previous installed repository :
sudo add-apt-repository --remove ppa:dobey/audiotools
sudo add-apt-repository --remove ppa:kxstudio-debian/apps
then remove any lmms installed if you have :
sudo apt-get remove lmms
this remove any previous installed files of lmms. Then you can install from your software center with no problem.
heemayl
  • 93,925
