EDIT: New info - the problem of Wifi not working after suspend is fixed by downgrading to kernel 3.2 - unfortunately the downgrade causes other problems like my mouse cursor freezing and lagging, and ubuntu keeps giving error messages. Only the downgrade solves the problem, an upgrade to kernel 4.0.4 changes nothing.
When I turn on my computer after it has been completely shut down, the wifi connection works fine. However, if I suspend then resume, I cannot detect any networks. How do I get it to work properly? I am a Linux newbie and do not have much experience fixing these kinds of issues.
I am using: Ubuntu 14.04.2. In case it matters, it is set up as a dual-boot with Windows 7.
This issue is not new for me, I have experienced it a while back before 14.04.2. This is the primary reason I do not use Linux - it is inconvenient and wastes time to restart my computer all the time just to use the Internet, so I would greatly appreciate a solution that actually works. I've looked up solutions but nothing works for me (they usually involved making or editing some weird config file that does nothing).
My wireless card is a TP Link TL-WN951N. It is supposedly supported by Linux from what I can find online.
Also, in case it matters, this is the result of typing
lspci -v | grep -A 10 -i "Network Controller"
into the terminal.
Network controller: Qualcomm Atheros AR5416 Wireless Network Adapter [AR5008 802.11(a)bgn] (rev 01)
Subsystem: Qualcomm Atheros Device 3071
Flags: bus master, 66MHz, medium devsel, latency 168, IRQ 19
Memory at fbef0000 (32-bit, non-prefetchable) [size=64K]
Capabilities: <access denied>
Kernel driver in use: ath9k
js sol
  • 173
Try to restart network-manager
sudo service network-manager restart
I have the same wifi card (TP Link TL-WN951N) using Kubuntu 14.04. After waking up my computer, the NetworkManager shows the wifi being connected, but it's not. If I disable and then enable wireless network using the NetworkManager, the wifi connects and works well. To make it automatic, I created a script /etc/pm/sleep.d/10_resume_wifi that does the same when a computer wakes up (inspired by this question):
#!/bin/sh
case "${1}" in
  resume|thaw)
    nmcli nm wifi off && nmcli nm wifi on;
esac
It's necessary to make the script executable:
sudo chmod +x /etc/pm/sleep.d/10_resume_wifi
