I understand this is very similar to this question and this one, but none of the answers there have worked for me. When trying to install the packages mentioned in those questions, apt-get throws up the following error message:
The following packages have unmet dependencies.
unity-webapps-service : Depends: webapp-container
When I try to install the dependencies mentioned there, I just find more and more dependencies. Synaptic Package Manager gives error messages when I select 'Fix Broken Packages'. How can I fix this?
Thanks in advance, and please comment if you need more information.
UPDATE:
Running apt-cache policy webapp-container unity-webapps-service gave the following result:
webapp-container:
Installed: (none)
Candidate: 0.23+14.04.20140428-0ubuntu1
Version table:
0.23+14.04.20140428-0ubuntu1 0
500 http://gb.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
0.23+14.04.20140414-0ubuntu1 0
500 http://gb.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
unity-webapps-service:
Installed: (none)
Candidate: 2.5.0~+14.04.20140409-0ubuntu1
Version table:
2.5.0~+14.04.20140409-0ubuntu1 0
100 /var/lib/dpkg/status
UPDATE 2: Version information:
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch:security-4.0-amd64:security-4.0-noarch:security-4.1-amd64:security-4.1-noarch
Distributor ID: Ubuntu
Description: Ubuntu 14.04.2 LTS
Release: 14.04
Codename: trusty
UPDATE 3:
When trying to install unity-webapps-service using aptitude instead of apt-get:
The following NEW packages will be installed:
liboxideqt-qmlplugin{a} liboxideqtcore0{a} liboxideqtquick0{ab}
libqt5feedback5{a} libqt5multimedia5{ab} libqt5organizer5{ab}
libqt5positioning5{ab} libunity-webapps0{a}
qtdeclarative5-dialogs-plugin{ab}
qtdeclarative5-privatewidgets-plugin{ab}
qtdeclarative5-qtfeedback-plugin{a}
qtdeclarative5-ubuntu-ui-extras-browser-plugin{a}
qtdeclarative5-ubuntu-ui-toolkit-plugin{ab} unity-webapps-qml{a}
unity-webapps-service webapp-container{ab} webbrowser-app{ab}
0 packages upgraded, 17 newly installed, 0 to remove and 0 not upgraded.
Need to get 26.6 MB of archives. After unpacking 103 MB will be used.
webapp-container : Depends: qtdeclarative-abi-5-2-1 which is a virtual package.
libqt5organizer5 : Depends: qtbase-abi-5-2-1 which is a virtual package.
qtdeclarative5-dialogs-plugin : Depends: qtbase-abi-5-2-1 which is a virtual package.
webbrowser-app : Depends: qtdeclarative-abi-5-2-1 which is a virtual package.
qtdeclarative5-privatewidgets-plugin : Depends: qtbase-abi-5-2-1 which is a virtual package.
libqt5multimedia5 : Depends: qtbase-abi-5-2-1 which is a virtual package.
libqt5positioning5 : Depends: qtbase-abi-5-2-1 which is a virtual package.
liboxideqtquick0 : Depends: qtdeclarative-abi-5-2-1 which is a virtual package.
qtdeclarative5-ubuntu-ui-toolkit-plugin : Depends: qtbase-abi-5-2-1 which is a virtual package.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) liboxideqt-qmlplugin [Not Installed]
2) liboxideqtcore0 [Not Installed]
3) liboxideqtquick0 [Not Installed]
4) libqt5feedback5 [Not Installed]
5) libqt5multimedia5 [Not Installed]
6) libqt5organizer5 [Not Installed]
7) libqt5positioning5 [Not Installed]
8) libunity-webapps0 [Not Installed]
9) qtdeclarative5-dialogs-plugin [Not Installed]
10) qtdeclarative5-privatewidgets-plugin [Not Installed]
11) qtdeclarative5-qtfeedback-plugin [Not Installed]
12) qtdeclarative5-ubuntu-ui-extras-browser-plugin [Not Installed]
13) qtdeclarative5-ubuntu-ui-toolkit-plugin [Not Installed]
14) unity-webapps-qml [Not Installed]
15) unity-webapps-service [Not Installed]
16) webapp-container [Not Installed]
17) webbrowser-app [Not Installed]
Accept this solution? [Y/n/q/?]
UPDATE 4:
The output of sudo apt-get install qtdeclarative-abi-5-2-1:
Reading package lists... Done
Building dependency tree
Package qtdeclarative-abi-5-2-1 is a virtual package provided by:
libqt5qml5 5.2.1-3ubuntu15.1 [Not candidate version]
libqt5qml5 5.2.1-3ubuntu15 [Not candidate version]
E: Package 'qtdeclarative-abi-5-2-1' has no installation candidate
The output of sudo apt-get install unity-webapp-container:
E: Unable to locate package unity-webapp-container
UPDATE 5:
Output of apt-cache policy libqt5qml5:
libqt5qml5:
Installed: 5.3.0-3ubuntu13~trusty1
Candidate: 5.3.0-3ubuntu13~trusty1
Version table:
*** 5.3.0-3ubuntu13~trusty1 0
500 http://ppa.launchpad.net/mscore-ubuntu/mscore-stable/ubuntu/ trusty/main amd64 Packages
5.2.1-3ubuntu15.1 0
5.2.1-3ubuntu15 0
Output of sudo apt-get install webapp-container:
Depends: unity-webapps-qml but it is not going to be installed
Depends: webbrowser-app (= 0.23+14.04.20140428-0ubuntu1)
