12
I frequently expand drives on my VMs. How can I rescan the drives without rebooting the server?
flickerfly
  • 7,509
The easiest solution is to use scsitools script rescan-scsi-bus.
sudo apt-get install scsitools
sudo rescan-scsi-bus
To do it without installing a utility on 14.04:
echo '1' > /sys/class/scsi_disk/0\:0\:0\:0/device/rescan
IMPORTANT: Be sure to replace the 0:0:0:0 with the appropriate disk for your purposes.
flickerfly
  • 7,509
10
Example for system disk without reboot:
  • Rescan the bus for the new size:
    # echo 1 > /sys/block/sda/device/rescan
  • Expand your partition (works with ansible):
    # parted ---pretend-input-tty /dev/sda resizepart F 2 Yes 100%
    - F for Fix
    - 2 for partition
    - Yes to confirm
    - 100% for whole partition
  • Resize it:
    # resize2fs /dev/sda2
Thierry42
  • 101
