I am using Oneiric Beta 2.
Installed it yesterday. Then downloaded 350+ MB of updates and installed it.
Then when I tried to auto-mount my drives using Storage manager, I screwed up and the system will boot right up to the Ubuntu Splash screen, then turn off.
Anyways planning to reinstall Ubuntu again. But I do not want to have to download the updates again. I have a copy of all the downloaded update files with me.
Can anyone tell me how I can install the updates from the hard drive without downloading them again ??
Thanks in advance.....
aj31
sudo dpkg -i *.deb will install all the .deb packages on the current directory in to your system.
Open a terminal, change the directory to where you saved your downloaded packages and use the command to install the packages that you previously saved.
If you have copied the packages to a USB pen, plug it in, open a terminal and change directory to where the USB pen was mounted (it should be a mount point under /media).
After you located the files you saved use the command to install the files.
Bruno Pereira
  • 74,715
