12
I'm using an Intel HD Graphics card.
For the last few days, for an unknown reason, some Steam games won't start up, including Half-Life and Garry's Mod.
Here's the shell output with Half-Life:
Game update: AppID 70 "Half-Life", ProcID 28160, IP 0.0.0.0:0
ERROR: ld.so: object '/home/s0/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
pid 28164 != 28163, skipping destruction (fork without exec?)
ERROR: ld.so: object '/home/s0/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Generating new string page texture 399: 128x256, total string texture memory is 3,84 MB
Using breakpad crash handler
Setting breakpad minidump AppID = 70
Forcing breakpad minidump interfaces to load
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198056430718 [API loaded yes]
Steam_SetMinidumpSteamID:  Setting Steam ID:  76561198056430718
assert_20150621233104_1.dmp[28171]: Uploading dump (out-of-process)
/tmp/dumps/assert_20150621233104_1.dmp
/home/s0/.local/share/Steam/SteamApps/common/Half-Life/hl.sh : line 38 : 28166 Segmentation fault  (core dumped) ${DEBUGGER} "${GAMEROOT}"/${GAMEEXE} $@
Game removed: AppID 70 "Half-Life", ProcID 28166
I've tried removing all the Steam Runtime libraries, but nothing changed.
Zanna
  • 72,312
You need the 32 bit libGL drivers (libgl1-mesaa-dri:i386).
You can issue this command via terminal,
sudo apt-get install libgl1-mesa-dri:i386
If you already have it, try reinstalling,
sudo apt-get install --reinstall libgl1-mesa-dri:i386
Restart your computer and try again.
If that doesn't work, check out this: Error loading libGL.so.1
woahguy
  • 592
