How can I fix this error I got while re-installing dropbox?
nautilus-dropbox : Depends: dropbox but it is not going to be installed
terdon
  • 104,119
Amogh Mishra
  • 101
I had a similar issue. I found the answer in the following post https://askubuntu.com/a/432485
Note the "sudo apt-get autoremove" which allows you to remove packages
so that you can do as follows to remove any broken packages.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get remove dropbox
sudo apt-get install dropbox
jasv
  • 36
