Is there a way to make the corners squared in ambiance or another theme for ubuntu 14.04?
I prefer the look and feel of squared corners.
proxe
  • 319
Edit unity.css;
  1. Open a terminal with Ctrl+Alt+t;
  2. Type in the terminal;
    cd /usr/share/themes/Ambiance/gtk-3.0/apps/
  3. Now type;
    sudo -i gedit unity.css
  4. In gedit (text editor) press Ctrl+f & in the search field that appears type;
    border-radius
  5. You should see the search phrase highlighted, our interest is in the proceeding text;
    : 6px 6px 0 0;
  6. Modify this text so that the line reads;
    border-radius: 0px 0px 0 0;
    I recommend keeping the px indicators in this line for easy future reference
  7. Save and Exit the document.
  8. Logout& back in, or change the theme & back again, enjoy!
This method should work with other themes as well, replacing Ambiance in the directory above with the appropriate theme package name;
/usr/share/themes/*theme-name*/gtk-3.0/apps/
Then modifying the corresponding unity.css file as before.
Keep in mind that for some themes there may be another border-radius entry in a separate css class within the same unity.css document that has to do with the window when it is not in focus.
This class will have the name;
UnityDecoration.top:backdrop
the border-radius value here will also need to be changed in order for square corners to work for windows currently unfocused.
proxe
  • 319
