I recently installed terminator in Ubuntu 14.04 TLS but when using the keyboard shortcut Ctrl+Alt +T it launches the terminator instead of the terminal. I'd like to regress back to having the shortcut launching the terminal but not sure how. Note that on the keyboard/Shortcuts/Launchers, the shortcut seems to be correctly mapped to 'Launch terminal'.
Many thanks!
Run sudo update-alternatives --set x-terminal-emulator $(which gnome-terminal.wrapper)
The system has x-terminal-emulator , which is symlinked to a particular program. When you've installed terminator , that symlink has been somehow changed to terminator. The command above will restore that to gnome terminal.
