I can not authenticate anything that requires GUI authentication...like approve software updates. After each try it says something like authentication was unsuccessful, and closes the dialog after 3 tries.
I am on Xubuntu 14.04 I am able to do sudo commands and authentications via the terminal, but nothing via the GUI.
I have tried changing the password via passwd and not using any special characters etc. But this seems above my head as I am fairly new to Xubuntu/Ubuntu. I am unable to update my system so if someone can remind me also of how to do it via terminal, but my main thing is to fix GUI authentication.
Any help appreciated.
Stuff I have tried:
This is not a match to any other question, as alluded, as this is: 1. a different version 2. Their solution of holding SHIFT did not work for me. 3. My issue started with GUI authentication issues first then sudo just disappeared later.
My user is a member of groups sudo and adm Sudo commands work fine Most gksudo commands like gksudo software-center fail to authenticate except gksudo xclock which works :-)
UPDATE To my surprise now when I sudo it says I am not in sudo. when I run GROUPS im not in sudo or adm anymore? Not sure why?
I tried to do the recovery thing...but when I reboot hitting or holding the shift does nothing. I have an SSD so my system boots in like 6 seconds. I have tried the shift key many times after when I see the blue Xubuntu screen, and before but nothing.
So now I need help accessing a root prompt on system so I can add myself to sudo..Ubuntu is a challenge is't it? :-)
