13
How can I fix this error when I try connecting to the ftp server on filezila:
GnuTLS error -15: An unexpected TLS packet was received.
And this error on sublime ftpsync plugin:
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1515)
This are my vsftpd settings:
listen=YES
anonymous_enable=NO
local_enable=YES
write_enable=YES
local_umask=022
nopriv_user=vsftpd
virtual_use_local_privs=YES
guest_enable=YES
user_sub_token=$USER
local_root=/var/www/$USER
chroot_local_user=YES
hide_ids=YES
guest_username=vsftpd
rsa_cert_file=/etc/ssl/private/vsftpd.pem
rsa_private_key_file=/etc/ssl/private/vsftpd.pem
ssl_enable=YES
allow_anon_ssl=NO
force_local_data_ssl=YES
force_local_logins_ssl=YES
ssl_tlsv1=YES
ssl_sslv2=NO
ssl_sslv3=NO
require_ssl_reuse=NO
ssl_ciphers=HIGH
5 Answers5
14
I tried adding a line to my configuration file. Open the config here:
sudo nano /etc/vsftpd.conf
And put this line at the bottom:
allow_writeable_chroot=YES
Afterwards, restart the service:
sudo service vsftpd restart
That fix it for me.
May be you have an error that has no relation with SSL.
  1. Try to deactivate SSL (ssl_enable=NO)
  2. Connect with your favorite FTP client.
Then you probably see the real error.
That's why the Francisc I.B answer has no relation with SSL.
d a i s y
  • 5,551
I ran into this same issue. Another thread advises against setting allow_writeable_chroot=YES for security reasons, namely to mitigate a "ROARING BEAST ATTACK".
Setting allow_writeable_chroot=YES means that vsftpd should allow the situation where the user's home directory is writeable by that user. Instead for security reasons I changed the permissions on the user's root folder from 777 to 555.
Original: drwxrwxrwx /home/ftpuser/
Changed to: dr-xr-xr-x /home/ftpuser/
This made the user's home directory NOT writeable by the user and thus I didn't have to use the allow_writeable_chroot=YES parameter. This is fine (and more secure) for my situation as I have a preset directory structure and don't want the user making new files or directories in their root folder anyways.
I figured this out when I switched the home directory to /var/ftp via the local_root=[path] parameter for vsftpd and it worked without having to set allow_writeable_chroot=YES. This folder /var/ftp is (755) but owned by root and thus not writeable by ftpuser.
Weirdly for me this issue cropped up when trying to ls after logging in.
It turned out to be that I had uninstalled httpd in favour of nginx and the folder I was using was owned apache:apache and the user got removed when I removed httpd. I chcon'd the directories to nginx:nginx and then replaced the user in these lines in my config file: guest_username=nginx nopriv_user=nginx
Hopefully this helps someone out there because the error messages weren't helpful at all.
I found so many confusing answers. I will post an
/etc/vsftpd.conf
that worked flawlessly for me in Ubuntu 18.04 using fileZilla as a client on 2019-09-04. The FTPS is deployed in an EC2 instance regulated by a very strict security group that only allows specific public IPS to access.
# FTPS Shim TLS configuration /etc/vsftpd.conf
# Run standalone?  vsftpd can run either from an inetd or as a standalone
# daemon started from an initscript.
# This directive enables listening on IPv6 sockets. By default, listening
# on the IPv6 "any" address (::) will accept connections from both IPv6
# and IPv4 clients. It is not necessary to listen on *both* IPv4 and IPv6
# sockets. If you want that (perhaps because you want to listen on specific
# addresses) then you must run two copies of vsftpd with two configuration
# files.
listen=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=NO
listen_port=38250
ftp_data_port=38255
# Allow anonymous FTP? (Disabled by default).
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=022
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# If enabled, vsftpd will display directory listings with the time
# in  your  local  time  zone.  The default is to display GMT. The
# times returned by the MDTM FTP command are also affected by this
# option.
use_localtime=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# If you want, you can have your log file in standard ftpd xferlog format.
# Note that the default log file location is /var/log/xferlog in this case.
xferlog_std_format=NO
# You may override where the log file goes if you like. The default is shown below.
xferlog_file=/var/log/vsftpd.log
log_ftp_protocol=YES
debug_ssl=YES
# You may change the default value for timing out an idle session.
idle_session_timeout=600
# You may change the default value for timing out a data connection.
data_connection_timeout=120
# You may fully customise the login banner string:
ftpd_banner=Welcome to Read-Only FTPS Shim service.
# You may restrict local users to their home directories.  See the FAQ for
# the possible risks in this before using chroot_local_user or
# chroot_list_enable below.
# This option should be the name of a directory which is empty.  Also, the
# directory should not be writable by the ftp user. This directory is used
# as a secure chroot() jail at times vsftpd does not require filesystem
# access.
secure_chroot_dir=/var/run/vsftpd/empty
# This string is the name of the PAM service vsftpd will use.
pam_service_name=ftp
# FTPS Passive Mode. -Define port range for passive mode connections
pasv_enable=Yes
pasv_min_port=10100
pasv_max_port=10110
ssl_enable=YES
# force client to use TLS when logging in
allow_anon_ssl=NO
ssl_tlsv1=YES
ssl_sslv2=NO
ssl_sslv3=NO
ssl_ciphers=HIGH
# specify TSL certificate/private key
rsa_cert_file=/etc/ssl/certs/fullchain.pem
rsa_private_key_file=/etc/ssl/private/privkey.pem
force_anon_logins_ssl=YES
# Uncomment this to indicate that vsftpd use a utf8 filesystem.
utf8_filesystem=YES
# Users
userlist_enable=YES
userlist_file=/etc/vsftpd.user_list
userlist_deny=NO
