A VLAN pool enabled newly is not pinging the device. Connectivity issues are not there.
  • Can this be because if ICMP Blocking is enabled?
  • How to check the status of the same?
ThrivingWithLinux
  • 1,072
To check whether ICMP is enabled or disabled run the command:
cat /proc/sys/net/ipv4/icmp_echo_ignore_all
The output is 0 or 1:
  • 0 means that ICMP is enabled
  • 1 means that ICMP is disabled
If it's disabled and you want to enable it:
  • change 1 to 0 in the above file
  • Or run the command:
    iptables  -I  INPUT  -i  ech0  -p   icmp  -s  0/0  -d  0/0   -j  ACCEPT
Maythux
  • 87,123
