Installed heat_docker plug-in and need to update "plugin_dirs" in heat.conf, in order for plugin to take effect. This works; however, upon charm update or reboot config file is overwritten. (Unlike, nova charm, where arbitrary parameters can be passed via "config-flags", there doesn't seem to be an equivalent field in heat charm.)
Any thoughts?
Cheers,
Asked
Active
Viewed 207 times
Nastooh
- 625
This is a rather ugly hack but you could try chattr +i heat.conf that is "change attributes add immutable" this would result in no accidental changes to the file. The downside to this approach is that you woud have to issue the command chattr -i heat.conf in order to allow any modifications to take place. This approach could easily result in unintended consequences such as normally required modifications to the file would fail unless you removed the immutable attribute before hand. Since this is like opening a can with a machette, I hope someone else has a better answer.
Elder Geek
- 36,752
