Gnu grub version 2.02 beta2-9 Minimal BASH-like line editing is supported. For the first word, TAB lists possible command completions. Anywhere else TAB lists possible device or file completions.
That's what comes up when I turn on my computer after deleting the Ubuntu partitions when I decided to get rid of it. If I type exit in the command line that comes up, it brings me to the windows boot manager and I can get to windows, but how do I get rid of the grub thing. Please help me fix this problem and be as detailed as possible.
The problem you are having is that grub is still installed in the MBR of the drive. Deleting the partitions does nothing to the MBR as it's in a separate reserved location. You can eliminate it by simply using your Windows installation and recovery disk to re-write the MBR How this works exactly may vary slightly dependant upon the version of Windows you are using. The recovery console commands fixboot and fixmbr come to mind.
Elder Geek
  • 36,752
