I have an older samsung laptop running dual core amd with 4 gigs ram, And I was previously running windows , due to severe lagging I installed ubuntu and now I am unable to boot up
It keeps showing
ACPI PCC probe failed
Starting version 219
Ata2:soft reset failed (1st FIS failed)
Alert /dev/disk/by-uuid/612a3bcc-0033-47bf-bcca-b6ad3a4224c8 does not exist..dropping to shell
And then it's says the the devices taking too long
Pilot6
  • 92,041
Hmm45
Well it seems like it can't detect your disk. You could try reinstalling if only some random bug hadn't happened, or type lsblk and see how are your disks/partitions named, from the install you can know, that if your disk is for example sda, than the first partition(typically ext3/ext4) will be sda1 and the second will be swap ... although I find this order not very logical. Now you know the disk where you installed is called sda1 so you go edit the file /etc/fstab and in the line containing this name /dev/disk/by-uuid/612a3bcc-0033-47bf-bcca-b6ad3a4224c8 you rename it to /dev/XXXY in this cas XXXY == sda1.
Hope it helps :)
IcyIcyIce
  • 1,159
