Yesterday, after some problems, finally I could install Ubuntu Server 14.04.2 and gnome GUI. Then I close the server. This morning, when I open it again it stops in this line: AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 set the 'ServerName' directive globally to suppress this message.
I've been looking for in Google, there are a lot of solutions, but no one works for me. Sure, because I'm new and there are a lot of things I don't know, but can somebody tell me how can I fix this problem? Please, step by step, I've tried to restart using recovery mode - root, but all commands fails.
Madhav Nikam
  • 2,967
You can manually edit file /etc/apache2/sites-enabled/000-default.conf (I am supposing you have a strictly default Apache configuration on your server).
You then change the line
    #ServerName www.example.com
and put in whatever IP address you use to connect from your clients, probably the server's IP address on eth0:
    ServerName 192.168.0.100
If you have a local DNS service up, you could also use your server's name, such as:
    ServerName www.localserver.local
In this case, both the clients and also the server will need to resolve this name.
Once this is written to the file, restart the Apache service (or reboot the computer) and the annoying message should go away for good.
HTH
ALAN WARD
  • 542
