Error mounting system-managed device /dev/sda3: Command-line `mount "/mnt/5CE0040FE003EDD8"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0). Metadata kept in Windows cache, refused to mount. Failed to mount '/dev/sda3': Operation not permitted The NTFS partition is in an unsafe state. Please resume and shutdown Windows fully (no hibernation or fast restarting), or mount the volume read-only with the 'ro' mount option.
Asked
Active
Viewed 793 times
Basically, the error message tells it all: at some point, your filesystem was not cleanly unmounted. This has been flagged, and the system will now not mount it until it has been checked. To do this, you need to :
In a terminal, become superuser
sudo bashIf the filesystem is mounted, unmount it
umount /dev/sda3Check the (now unmounted) filesystem
ntfsfix /dev/sda3You can now remount it as indicated in /etc/fstab:
mount /dev/sda3
HTH.
ALAN WARD
- 542
