I have VSCode installed on Ubunutu 14.04 64-bit but when it's launched from terminal there is this error:
[6303:0615/111654:ERROR:browser_main_loop.cc(170)] Running without the SUID sandbox! See https://code.google.com/p/chromium/wiki/LinuxSUIDSandboxDevelopment for more information on developing with the sandbox on.
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
Is this something I should fix or it is coming from VSCode?
Also is there a way to launch it from terminal but terminal not to stay open all the time?
NexusStar
  • 573
Since it seems safe to ignore the startup errors, add this to your .bashrc:
function __code {
   if [ "$@x" != 'x' ]; then
      (~/path/to/Code "$@" &) &> /dev/null
   else
      (~/path/to/Code &) &> /dev/null
   fi
alias code='__code'
This will allow you to use the same calling convention as in the documentation.
If you don't want to suppress the errors just remove the &> /dev/null bit.
Also don't forget to replace ~/path/to with the actual path where you extracted the zip file to.
A set uid sand box is to help limit interprocess communication. Worth looking into if you are interested in stepping up security, but not needed for Code to run right.
To launch an application (Code in his case) from a terminal and to be able to close the terminal use disown.
Code &
disown
And to redirect the CLI output from the program into a file use
Code &> /dev/null
putting the two together to launch Code with no terminal output, and the ability to close the window:
Code &> /dev/null &
disown
cargo
  • 371
