17
Is there a way to delete lines starting with certain strings.
I have this youtube-dl code
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E
and its result is like this
[youtube:playlist] PL1C815DB73EC2678E: Downloading webpage
[download] Downloading playlist: Less than 1 minute
[youtube:playlist] playlist Less than 1 minute: Collected 4 video ids (downloading 4 of them)
[download] Downloading video 1 of 4
[youtube] KNLwsqzFfNg: Downloading webpage
[youtube] KNLwsqzFfNg: Extracting video information
[youtube] KNLwsqzFfNg: Downloading DASH manifest
[download] Destination: _1 min. - Amendes pour les particules du LHC-KNLwsqzFfNg.m4a
[download]   0.4% of 231.51KiB at  6.10KiB/s ETA 00:30
[download]   1.1% of 231.51KiB at 27.07KiB/s ETA 00:10
[download]   4.0% of 231.51KiB at 19.24KiB/s ETA 00:04
[download]   6.5% of 231.51KiB at 75.06KiB/s ETA 00:03
[download]  13.4% of 231.51KiB at 98.22KiB/s ETA 00:03
[download]  28.7% of 231.51KiB at 81.40KiB/s ETA 00:02
[download]  61.7% of 231.51KiB at 91.56KiB/s ETA 00:01
[download]  86.2% of 231.51KiB at 82.96KiB/s ETA 00:00
[download] 100.0% of 231.51KiB at 73.21KiB/s ETA 00:00
[download] 100% of 231.51KiB in 00:02
[ffmpeg] Correcting container in "_1 min. - Amendes pour les particules du LHC-KNLwsqzFfNg.m4a"
WARNING: Your copy of avconv is outdated, update avconv to version 10-0 or newer if you encounter any errors.
[avconv] Destination: _1 min. - Amendes pour les particules du LHC-KNLwsqzFfNg.mp3
Deleting original file _1 min. - Amendes pour les particules du LHC-KNLwsqzFfNg.m4a (pass -k to keep)
[download] Downloading video 2 of 4
[youtube] wTvXkMpJflk: Downloading webpage
[youtube] wTvXkMpJflk: Extracting video information
[youtube] wTvXkMpJflk: Downloading DASH manifest
I want to delete all lines starting with [youtube], [ffmpeg] and [avconv] and get like this
etc..
etc..
i tried this method but its showing error and it only suppose to delete [youtube]
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E | sed '^/[youtube]/ d'
5 Answers5
17
sed -i '/\[youtube\]/d' /path/to/file
will delete lines, containing "[youtube]".
As one command you can combine patterns like
sed -i '/\[youtube\]\|\[ffmpeg\]\|\[avconv\]/d' /path/to/file
Or right from your command
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 \
    sed '/\[youtube\]\|\[ffmpeg\]\|\[avconv\]/d' > output.txt
This will write the result to a file output.txt.
If you want to delete lines not just containing [youtube], but starting with [youtube], then add ^ to the pattern, like sed '/^\[youtube\]/d'.
But in your case it does not matter.
terdon
  • 104,119
Pilot6
  • 92,041
I suggest using grep -vE like so:
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E | grep -vE '^\[(youtube|ffmpeg|avconv)\]'
From man grep:
-v, --invert-match
              Invert the sense of matching, to select non-matching lines.  (-v
              is specified by POSIX.)
-E, --extended-regexp
              Interpret  PATTERN  as  an extended regular expression (ERE, see
              below).  (-E is specified by POSIX.)
The -E flag is used to avoid escaping square brackets with slashes. Without -E flag you have to escape the square brackets with a backslash, like so grep -vE '\[youtube\]\|\[ffmpeg\]\|\[avconv\]' Edit:
Since you've requested awk,here's one with awk:
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E | awk '{if ($0~/^\[youtube\]/||/^\[ffmpeg\]/||/^\[avconv\]/||/^WARNING/) next;print}'
Use grep -v as following:
youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E | grep -v '^[youtube]' | grep -v '^[ffmpeg]' | grep -v '^[avconv]'
Using Perl:
< inputfile perl -pe 's/^\[(youtube|ffmpeg|avconv)\].*$//' > outputfile
To parse the output of youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E directly, pipe its output to the command without redirecting the content of inputfile:
`youtube-dl --extract-audio --audio-quality 0 --newline --audio-format mp3 https://www.youtube.com/playlist?list=PL1C815DB73EC2678E | perl -pe 's/^\[(youtube|ffmpeg|avconv)\].*$//' > outputfile`
  • < inputfile: redirects the content of inputfile to perl's stdin
  • > outputfile: redirects the content of perl's stdout to outputfile
  • -p: places a while (<>) { [...] } loop around the script and prints each processed line
  • -e: reads the script from the arguments
Perl script breakdown:
  • s: asserts to perform a substitution
  • /: starts the pattern
  • ^: matches the start of the line
  • \[: matches a [ character
  • (: starts grouping the allowed strings
  • youtube: matches a youtube string
  • |: separates the second allowed string
  • ffmpeg: matches a ffmpeg string
  • |: separates the third allowed string
  • avconv: matches a avconv string
  • ): stops grouping the allowed strings
  • \]: matches a ] character
  • .*: matches any number of any character
  • $: matches the end of the line
  • /: stops the pattern / starts the replacement string
  • /: stops the replacement string
kos
  • 41,268
Here is a similar question with easy answer
https://askubuntu.com/questions/1493280/remove-lines-from-a-txt-file-that-start-with-a-special-string?noredirect=1#comment2616486_1493280
D-T
  • 506
