Tell me please which are the best ways to check the temperature of the CPU and other hardware components in Lubuntu?
It would be better if the applications could even tell me which are the normal average temperatures or temperatures in which should fit my hardware configuration.
Thank you.
XPDIN
  • 595
you could try Psensor, you can download it in the Ubuntu software center. It gives you a desktop app which shows you the temperature of te cores, cpu, cpu load and the bridge temperatures.
it also enables you to set warnings for certain temperatures.
You need lm-sensors
sudo apt-get install lm-sensors
Then run:
sudo sensors-detect
finsish the requests then run the command
sensors
Sample output:
coretemp-isa-0000
Adapter: ISA adapter
Core 0:      +59°C  (high =  +100°C)
coretemp-isa-0001
Core 1:      +59°C  (high =  +100°C)
coretemp-isa-0002
Core 2:      +55°C  (high =  +100°C)
coretemp-isa-0003
Core 3:      +56°C  (high =  +100°C)
Check this source for more information
Maythux
  • 87,123
