I trying to install wine with
sudo apt-get install wine1.6
and Terminal showing this
Reading package lists... Done
Building dependency tree
 wine1.6 : Depends: wine1.6-i386 (= 1:1.6.2-0ubuntu4) but it is not installable
           Recommends: cups-bsd but it is not going to be installed
           Recommends: gnome-exe-thumbnailer but it is not going to be installed or
                       kde-runtime but it is not going to be installed
           Recommends: fonts-droid but it is not going to be installed
           Recommends: fonts-liberation but it is not going to be installed
           Recommends: ttf-mscorefonts-installer but it is not installable
           Recommends: fonts-horai-umefont but it is not going to be installed
           Recommends: fonts-unfonts-core but it is not going to be installed
           Recommends: ttf-wqy-microhei
           Recommends: winbind but it is not going to be installed
For Wine to work on a 64 bit machine, you need to enable support for i386 architecture. To do this, follow these steps:
Check that the only file in the below folder is multiarch using:-
ls /etc/dpkg/dpkg.cfg.d/
See if the output is multiarch. If the output is multiarch then run below:-
sudo sh -c "echo 'foreign-architecture i386' > /etc/dpkg/dpkg.cfg.d/multiarch"
NOTE:- First, check the output of uname -m, if it is already i386, then no-need to follow above steps, i.e, i386 is enabled by default.
Above is quoted from my answer here.
Follow the above steps and then do:
Before trying to install wine, add the wine ppa in the sources list by the command sudo add-apt-repository ppa:ubuntu-wine/ppa. Then update the sources using sudo apt-get update. Now install wine using sudo apt-get install wine1.6.
GOOD LUCK...
