I have a new HP Pavilion 15 with windows 8.1, and want to have Ubuntu alongside it. I created an Ubuntu 14.04 liveDVD, disabled fast boot, and changed the boot order. Then I installed Ubuntu. After that the computer still went straight to Windows (when the DVD was not in), so I disabled secure boot (even though some web pages say it's not necessary - can I put it back?). After that I followed all the instructions in Ubuntu 14.04 LTS release doesn't boot after being installed .
After the last step I got this link with tons of info.
All steps here completed without any error message, but still I go straight to Windows.
Okay so there are are two things that could be happening here.
A) You mentioned secure boot, implying a UEFI system. You may have installed the BIOS boot version of GRUB.
B) You need to use a program such as EasyBCD to add a Linux entry into the Windows boot loader menu and make it visible on boot. Just Google EasyBCD for more info.
Hope this helps !!!
I have had problems with 14.04 on a newer laptop, but from some reading I found that 15.04 has the capability to install with secure boot enabled. I tried it two days ago and it worked just fine. I only disabled fast boot, but left secure boot enabled in UFEI. I have had success installing 14.04 after I disabled secure boot and fast startup. You might want to leave the UFEI in insecure boot and try to reinstall Ubuntu 14.04.
Blake
  • 101
Perhaps your Master Boot Records is damaged.
  1. Burn Ubuntu Live USB / DVD (You can do it via Unetbootin).
  2. Boot the machine in Live Ubuntu environment.
  3. Open up terminal and type
    sudo add-apt-repository -y ppa:yannubuntu/boot-repair;
    sudo apt-get update;
    sudo apt-get install -y boot-repair && boot-repair
  4. Once the boot-repair window pops up , click on recommended repair.
  5. Reboot. This might do the trick
Ravexina
  • 57,256
Mayur Kulkarni
  • 550
  • 14
according to your report there is No boot loader installed...
you have to (re)install GRUB, the default boot loader of Ubuntu.
please have a look at: https://help.ubuntu.com/community/Grub2/Installing
DJCrashdummy
  • 1,922
