Please don't mark it as duplicated. I've tried a lot but can't make it working.
I've installed LAMP using tasksel. Everything is fine but having file permission error (While installing WordPress I get this error "Sorry, but I can’t write the wp-config.php file." )
I can create the file manually but I don't want to do this. I wasn't to make it working correctly.
What I did to set up permission after installing lamp
cd /var/wwww/
sudo chown -R username:www-data /var/www/html/
sudo chmod 775 /var/www/html/
sudo chmod g+s /var/www/html/
Later I tried some solutions like sudo chown -R [USER NAME]:[USER NAME] /var/www which I found on askubuntu.
I don't know much about permission issue trying solution blindly.
Can you please help me on this to make it working? :)
Output of ls -l /var/www
Output of total 4
drwxrwsr-x 3 h3mdsa h3mdsa 4096 Jun 12 16:40 html
(Thanks @Jos for comment)
Thanks in advanced,
Md Al Amin
