I'm trying to screencast with both mic and system sounds at the same time. Previously this didn't work, but I have found that fiddling with the sound profile brings me a step closer.
To fiddle with sound profile:
  • Click on Sound menu
  • Select "Sound Preferences..."
  • Select "Hardware" tab
  • Choose the device to configure (I have two "Internal Audio" and "Logitech USB Headset")
  • Select option from Profile dropdown
  • Click "Test Speakers" to test output
So far so good. Previously I had Internal Audio set to "Analog Stereo Duplex" and the headset also on "Analog Stereo Duplex". When I recorded a screencast in Tibesti and played it back, I could hear myself but not the system sounds (for example, music player or Skype call).
I switched Internal Audio to "Digital Stereo Duplex (IEC958)". Under the "Output" tab I selected internal audio as the output. When I recorded a screencast in Tibesti and played it back, I could hear myself and the system sounds. Unfortunately, I couldn't hear the system sounds while recording, which means screencasting a Skype call couldn't work.
The internal audio profiles are: Analog Stereo Duplex, Analog Stereo Output, Digital Stereo (IEC958) Output + Analog Stereo Input, Digital Stereo Duplex (IEC958), Digital Stereo (HDMI) Output + Analog Stereo Input, Digital Stereo (HDMI) Output, Analog Stereo Input, Off.
The headset audio profiles are: Analog Stereo Duplex, Analog Stereo Output, Analog Stereo Input, Off.
Which profile combination and input/output selection will allow me to simultaneously hear and record system audio + microphone input?
lofidevops
  • 21,912
No sound profile selection will achieve the results you are looking for. Instead you could mix voice and audio channels (follow link for step-by-step details).
You might want start with this article from the same blog for background High quality audio broadcasting with Flipzu and Ubuntu Linux, or this "weekend project" for a lot more technical detail: Record From Skype Calls and Other Apps on Linux.
gpoo
  • 414
install & use pavucontrol
sudo apt-get install pavucontrol
executable : /usr/bin/pavucontrol
this software monitor audio output and can map audio input to monitors.
iCoco
  • 297
