I was trying to connect to wi-fi with lubuntu but I could not, I don't know exactly what is the problem, I used nm-applet and that was the result:
    nm-applet
** (nm-applet:13926): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(nm-applet:13926): nm-applet-WARNING **: Failed to register as an agent: (32) An agent with this ID is already registered for this user.
nm-applet-Message: using fallback from indicator to GtkStatusIcon
UPDATE:
So I re-install it and tried again, the result as following:
family@family-HP-Compaq-6735s:~$ lspci -knn | grep Net -A2
06:00.0 Network controller [0280]: Broadcom Corporation BCM4312 802.11b/g LP-PHY [14e4:4315] (rev 01)
    Subsystem: Hewlett-Packard Company BCM4312 802.11b/g Wireless LAN Controller [103c:137d]
    Kernel driver in use: b43-pci-bridge
family@family-HP-Compaq-6735s:~$  nm-applet
** (nm-applet:2333): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(nm-applet:2333): nm-applet-WARNING **: Failed to register as an agent: (32) An agent with this ID is already registered for this user.
dekup
If you can connect to internet by wire, then just run in terminal
sudo apt-get install bcmwl-kernel-source
sudo modprobe -r b43 bcma
If you can't connect another way, then use THIS METHOD
Pilot6
  • 92,041
For me, installing 'at-spi2-core' allowed me to run nm-applet successfully, and connect to a wifi network.
sudo apt install at-spi2-core
Gino
  • 260
