Downloaded genymotion and trying to access it by following their instructions. In the terminal, I've changed directory to where the file is, used chmod +x genymotion-2.4.0_x64.bin and sudo ./genymotion-2.4.0_x64.bin and it gives me sudo: ./genymotion-2.4.0_x64.bin: command not found.
Asked
Active
Viewed 4,868 times
Solved by OP in Question
I was trying to execute it from the directory I had it in which was in a different partition than my home folder. I moved it to home and right clicked and selected
Allow executing file as programfrom the permissions tab of the properties, followed the previous steps adding the directory I was in as the install folder, and it worked. Which only opens up new questions for me... Why couldn't I execute the file in the target folder, why couldn't I clickAllow executing file as programin the original directory, and why did I have to move the.binfile to the home folder?
Tim
- 33,500
