I am using Ubuntu 14.04LTS on Lenovo G580. The Function key is working fine for brightness change, but I want to make the change smoother, i.e. reduce the step change in brightness per key press. Any Ideas on how to do that?
you can also increase and decrease the brightness from present value to specified level.as you mentioned if you want to increase to 10% from current value of brightness then you can give this
xbacklight -inc 10
and to decrease 10% you can give this
xbacklight -dec 10
Source
Maybe you want to change the 10 to 5 or even 3, to have a slower transition, so use
xbacklight -inc 5
and
xbacklight -dec 5
To reassign the keyboard short cuts - using the GUI - follow this:
Open system settings, and click keyboard.
Click Shortcuts, then custom shortcuts.
Click [+] then type the following (ignore what I put in the image):
Brightness Up
 xbacklight -inc 5
Click disabled and press your chosen shortcut key:
And repeat for the brightness down.
Tim
  • 33,500
