I know that using the history command I can view my past commands, but:
  • Is there a way to view the date and time of the execution of those commands?
  • Or is that kind of information not saved?
  • And if that sort of information is not saved, is there any way to make it so that it does save it so that I can view it later?
Maythux
  • 87,123
Try to run this command from terminal:
HISTTIMEFORMAT="%d/%m/%y %T "
Then now run history:
history
sample output:
 2000  10/06/15 15:49:29 pal -d
 2001  10/06/15 15:49:33 pal -d 10
 2002  10/06/15 15:49:49 pal -d 04 Jul 2015
 2003  10/06/15 15:50:36 gedit/home/maythux/.pal/pal.conf
 2004  10/06/15 15:50:40 gedit /home/maythux/.pal/pal.conf
 2005  10/06/15 15:53:30 cal
 2006  10/06/15 15:53:31 gcal
 2007  10/06/15 15:53:34 sudo apt-get install gcal
 2008  10/06/15 15:53:54 gcal
 2009  10/06/15 15:53:57 man gcal
 2010  10/06/15 15:54:03 pal
 2011  10/06/15 15:55:35 pal -m
 2012  10/06/15 15:56:56 history
 2013  10/06/15 15:57:39 HISTTIMEFORMAT="%d/%m/%y %T "
 2014  10/06/15 15:57:45 history
To make this permanent add to your .bashrc:
echo 'export HISTTIMEFORMAT="%d/%m/%y %T "' >> ~/.bashrc
Then source your bashrc:
source .bashrc
Now the sample output will be available whenever you run the command history
Maythux
  • 87,123
