When I press tab in terminal it goes very far. So I would like to change tab width, make it smaller. Anyone could help me, please?
Asked
Active
Viewed 3.7k times
41
You can set the tab width on any terminal to 4 (for example) by using the following command:
tabs -4
You can also set an explicit tablist. Consider looking at the man page.
Talia Stocks
- 510
- 4
- 5
If you are referring to using the Tab key in the terminal, I found this at UF. Ubuntu Forums Thread #7788701:
A possibility is setting the spacing in the application you are using via the terminal. For example in vim - :set tabstop=4 .
Or you could look into the man page for the expand command with man expand. Example of usage - expand -t 4 mytextfile.txt - this would convert the tab spacing when viewing a file from the default 8 to 4.
Nitin Venkatesh
- 22,739
