I have installed minicom through the following command:
sudo apt-get minicom
I am connected with the HP 5130 switch through a USB to Serial Console Cable. The name of my serial port is /dev/ttyUSB0 according to following command:
dmesg | grep tty
[    0.000000] console [tty0] enabled
[49689.082419] usb 3-2: pl2303 converter now attached to ttyUSB0
Extra check:
ls -l /dev/ttyUSB0
If I unplug the USB cable, I get following error:
ls: cannot access /dev/ttyUSB0: No such file or directory
So I assume its correct that ttyUSB0 is the right port
I edited the settings of minicom as following:
| A -    Serial Device      : /dev/ttyUSB0                              |
| B - Lockfile Location     : /var/lock                                 |
| C -   Callin Program      :                                           |
| D -  Callout Program      :                                           |
| E -    Bps/Par/Bits       : 9600 8N1                                  |
| F - Hardware Flow Control : Yes                                       |
| G - Software Flow Control : No                                        |
|    Change which setting?                                              |
and started minicom
However, I don't get any output except this:
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Jan  1 2014, 17:13:22.
Port /dev/ttyUSB0, 15:02:26
Press CTRL-A Z for help on special keys
CTRL-A Z for help | 9600 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyUSB0
I think the problem lies in the offline status?
Noosrep
  • 2,184
See this part ...
Change it to "No" (or off ... whatever) and restart minicom.
When you unplug and re-plug USB in the device is changed to /dev/ttyUSB1 or /dev/ttyUSB2 depends on how many time you re-plug the USB. Try connect with another device.
From error ls: cannot access /dev/ttyUSB0: No such file or directory I believe that the terminal controller is changed to /dev/ttyUSBX when you re-plug the USB.
eetsurt
  • 158
Just ls /dev/ttyUSB* and then sudo minicom -D /dev/ttyUSBx
You can also use my shell script that openw all of your minicom in new terminals:
#!/bin/bash
open_minicom(){
PORT_IP=2
PORT_IP=$((PORT_IP+$1))
gnome-terminal -t "Minicom port $1 - 192.168.1.$PORT_IP" -x ./tmp_script"$1".sh
#./minicom_PORT.sh "$PORT_NUM"
generate_script(){
echo "$1"
PORT_NUM="$1"
PORT_IP=2
#gconftool-2 --set /apps/gnome-terminal/profiles/Default/title --type=string "Minicom port $PORT_NUM"
#############################generat script
touch tmp_script"$1".sh
chmod 777 tmp_script"$1".sh
cat <<EOT >> tmp_script"$1".sh
#!/usr/bin/expect -f
spawn sudo minicom -D /dev/ttyUSB$PORT_NUM -S set_ip"$PORT_IP".sh
expect {
-re ".*sword.*" {
    exp_send "$pass\r"
interact
EOT
#open terminal
generate_eth(){
PORT_IP=2
touch set_ip"$PORT_IP".sh
chmod 777 set_ip"$PORT_IP".sh
cat <<EOT >> set_ip"$PORT_IP".sh
#!/bin/bash
ifconfig eth0 192.168.1.$PORT_IP down up
EOT
MY_distractor(){
rm tmp_script*.sh set_ip*.sh
#printf "\n$NUM_OF_PORTS\n"
#             MAIN           #
NUM_OF_PORTS="$(ls /dev/ttyUSB* | grep -v ^l | wc -l)"
if [ $# -eq 0 ]
  then
    printf "No password arguments supplied\n Plase run ./your_script password \n Exiting......\n" && exit 1;
else
    pass="$1"
fi
if [ "$NUM_OF_PORTS" == "0" ]; then
    printf "Not found any minicom ports\n Exiting......\n" && exit 1;
fi
for (( i=0; i < $NUM_OF_PORTS ; i++ ))
do
    generate_script "$i"
done
echo "$(ls tmp_script*.sh)"
do
    generate_eth "$i"
done
do
    open_minicom "$i"
done
sleep 1
MY_distractor
karel
  • 122,292
  • 133
  • 301
  • 332
