I'm using pbuilder-dist to test a build against a specific Ubuntu release and architecture. When I build SiLK 3.10.2 for i386 on 14.04 (trusty), one of the make tests fail:
make[5]: Entering directory `/tmp/buildd/silk-3.10.2/src/rwconvert'
PASS: tests/rwallformats-help.pl
PASS: tests/rwallformats-version.pl
PASS: tests/rwallformats-lone-command.pl
PASS: tests/rwrtd2split-help.pl
PASS: tests/rwrtd2split-version.pl
PASS: tests/rwrtd2split-lone-command.pl
FAIL: tests/rwallformats-all.pl
Testsuite summary for SiLK 3.10.2
# TOTAL: 7
# PASS:  6
# SKIP:  0
# XFAIL: 0
# FAIL:  1
# XPASS: 0
# ERROR: 0
See src/rwconvert/test-suite.log
Please report to netsa-help@cert.org
make[5]: *** [test-suite.log] Error 1
make[5]: Leaving directory `/tmp/buildd/silk-3.10.2/src/rwconvert'
make[4]: *** [check-TESTS] Error 2
make[4]: Leaving directory `/tmp/buildd/silk-3.10.2/src/rwconvert'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/tmp/buildd/silk-3.10.2/src/rwconvert'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/tmp/buildd/silk-3.10.2/src'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/tmp/buildd/silk-3.10.2'
dh_auto_test: make -j1 check returned exit code 2
make: *** [build] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
E: Failed autobuilding of package
I: unmounting dev/pts filesystem
I: unmounting run/shm filesystem
I: unmounting proc filesystem
I: cleaning the build env
I: removing directory /var/cache/pbuilder/build//37742 and its subdirectories
I would like to get the log file src/rwconvert/test-suite.log the output above refers to, but how can I extract this file from the chrooted build environment, or get pbuilder-dist to output this file as well?
PS: my $HOME/pbuilder/trusty-i386_result/ directory only contains the console output and a log file called last_operation.log. But last_operation.log lists only the output from the cleaning of the build environment (which is executed after the build failed).
toringe
  • 111
Found a way to solve this, so I'll answer my own question.
The solution was to use a hook script to pbuilder. The linked article describe it well, but for the sake of completeness, I'll redo the steps here:
First create a directory for you hook scripts:
sudo mkdir /var/cache/pbuilder/hook.d
Then add this directory to pbuilder's configuration:
echo HOOKDIR=\"/var/cache/pbuilder/hook.d\" >> ~/.pbuilderrc
Create a hook script called C10shell with the following contents:
#!/bin/sh
# invoke shell if build fails.
apt-get install -y --force-yes vim less bash
cd /tmp/buildd/*/debian/..
/bin/bash < /dev/tty > /dev/tty 2> /dev/tty
Save it to your HOOKDIR, and make it executeable
sudo chmod a+x /var/cache/pbuilder/hook.d/C10shell
Now, if the build fails, you will be presented with a root shell within the chrooted environment of pbuilder.
toringe
  • 111
