24
I've tried to search this topic in google, but without any significant results.
I need to start some GUI app from terminal, but I don't care what this app is showing me. In addition, I need to start few instances of this application in different sessions. It's connected with some GUI automated tests, so I know what I want and I'm looking for an answer :).
I think the proper steps should be:
  1. Init new X window session
  2. Get my new session id
  3. export it to env variable (export DISPLAY:13.0)
  4. run my app
but I'm stuck at first step. does anybody here had similar problem?
--- EDIT: 1) I don't care about GUI output - i need only stdout and stderr from my app. - that's why this question is not duplicate - know google well :) . I don't want to redirect output to my own GUI.
If you don't care to see what the application is doing, you can supply it with a "virtual" x server with xvfb:
Xvfb provides an X server that can run on machines with no display hardware and no physical input devices. It emulates a dumb framebuffer using virtual memory. The primary use of this server was intended to be server testing, but other novel uses for it have been found, including testing clients against unusual depths and screen configurations, doing batch processing with Xvfb as a background rendering engine, load testing, as an aid to porting the X server to a new platform, and providing an unobtrusive way to run applications that don't really need an X server but insist on having one anyway.
After installing it, you can start it with:
sudo Xvfb :10 -ac -screen 0 1024x768x24 &
it'll run in the background, then you start your clients with:
DISPLAY=:10 your-client
roadmr
  • 34,802
20
A short command:
ssh -X <username>@<host> gedit &
from man ssh
-X      Enables X11 forwarding.
        This can also be specified on a per-host basis in a configuration file.
        X11 forwarding should be enabled with caution.  Users with the
        ability to bypass file permissions on the remote host (for the
        user's X authorization database) can access the local X11
        display through the forwarded connection. An attacker may then
        be able to perform activities such as keystroke monitoring.
  1. Check /etc/ssh/sshd_config on the server side:
    sudo nano /etc/ssh/sshd_config
    for the lines below:
    X11Forwarding yes
    X11UseLocalhost no
    Restart the ssh srever, if you have made changes:
    sudo service ssh restart
  2. Check /etc/ssh/ssh_config on the client side:
    sudo nano /etc/ssh/ssh_config
    for the lines below
    ForwardX11 yes
    ForwardX11Trusted yes
A.B.
  • 92,125
14
You just need to run export DISPLAY=:id# in your ssh session and programs run will run on the remote display. A quick example:
maythux@maythuxPC:~$ ssh testSSH@myServer
maythux@maythuxPC:~$ export DISPLAY=:0
maythux@maythuxPC:~$ gedit
Now gedit will run on the user named testSSH display
You can shorten this all down into single command:
ssh testSSH@myServer "DISPLAY=:0 nohup gedit"
Maythux
  • 87,123
