34
I have share-it software in windows O/S and android phone both. Using this software I can easily transfer my file over Wi-Fi. Is there any software like share-it in Ubuntu 14.04, where I can transfer my file at android phone using wifi.
Anwar
  • 77,855
Tusher
  • 403
6 Answers6
32
Using FTP
Here is another way to easily transfer files between your laptop and Android phone.
Prerequisite:
Procedure:
  1. If both your Android and Ubuntu are connected to the same WiFi (same LAN), skip to step 3. Otherwise, create a WiFi hotspot on your Android:
    settings -> "wireless & networks" -> more
    enable hotspot
  2. Connect your laptop to this WiFi network.
    connect to hotspot
  3. Open ES File Explorer and open left-side menu.
    open menu
  4. Go to Network -> Remote Manager
    network -> remote manager
  5. Turn on the FTP Server and note down the IP:port address
    turn on FTP
    get IP address and port
  6. Open Nautilus file explorer on Ubuntu. In connect to URL, type your phone's FTP server URL (from the previous step) and click on Connect
    connect to FTP server in Nautilus
  7. If you need, You can set user name and password in ES File Explorer. By default, It will be public (anonymous).
    access settings in ES
  8. In your PC, click on Connect. You can use the username and password that you set in ES File Explorer and connect as registered user.
    log in to FTP server
  9. Now the internal memory of your phone is mounted. You can copy new files, remove files, do anything.
    Phone storage mounted in Nautilus
    If you wish to mount your SD card, you can set that in ES File Explorer settings.
wjandrea
  • 14,504
Severus Tux
  • 10,126
Airdroid
Install the Android app, then to transfer files using wifi, you can use web.airdroid.com, or the local address (in my case, 192.168.0.102:9000). It doesn't need an active internet connection.
rainu
  • 291
I've been looking for a solution to run SHAREit on Ubuntu without success, here's what I figured what is the most hassle-free approach, though it requires a Windows License of some sort:
  1. Install Virtualbox on your Ubuntu box if you haven't already
  2. Install a Windows from XP and up
  3. Install SHAREit on Windows
  4. Configure your local SHAREit folder on the Windows guest as a shared one with the host, if you need to access the files on your Ubuntu-box
Hope it helps!
gfaw
  • 31
You can now send any files from your phone with ShareIt app to linux without any setup. ShareIt has got a feature "New Way of Connect to PC" which directly uses hotspot of the mobile to send file to PC. To use it: Open ShareIt app -> Scroll Down to above option and follow the instructions.
Basically, at the receiving end, you need to connect to the host WiFi hotspot and navigate to a URL using a simple browser to download things. The ShareIt app serves the shared files at a local URL over it's network which can be downloaded via browser after connecting to hotspot.
Edit: This is not related to ShareIt but I find Xender app much more easy and fast to connect to PC and transfer files. Just navigate to web.xender.com scan QR code from its app and there! you are good to go!!
krozaine
  • 131
If you don't need internet then use super beam pro for computer to phone transfer.
Requirments:
  • Android devices must have PRO version of SuperBeam installed in order to work with PC app.
  • Java 6 or later
wjandrea
  • 14,504
Rafi
  • 29
I know you asked about shareit. But try KDEconnect, https://kdeconnect.kde.org/
Moyo Freeman
  • 355
