I just installed lamp-server^ and wanted to try it I created a php file but I was not able to move it to /var/www because owner of that folder is root I managed it using terminal (I logged in as root). But I dont want to do it everytime. Is there any other way to do it? I dont want to use terminal every time I want to try to access that folder.
Tim
  • 33,500
Kdaydin
  • 111
I don't know how it is done in LAMP, but a pure Apache setup has a user group called www-data with write permission into /var/www.
To achieve the same result, follow these steps:
  1. Create the group www-data, if not already existent (check with grep www-data /etc/group):
    groupadd www-data
  2. Transfer group ownership of /var/www to www-data, if not already done:
    sudo chgrp www-data /var/www
  3. Add your user to the www-data group:
    sudo usermod -a -G www-data <username>
  4. Fix permissions, if necessary (give full permission to group members):
    sudo chmod g+rwx /var/www
Now you can access the directory without sudoing.
s3lph
  • 14,644
  • 60
  • 83
